Show messages: All
1-2
3-16
I can import it in Onshape, but when I want to make technical drawings I face problem!
-Psygorn
Puncher_Top_Part.stp
Hi Psygorn,
> Also @Michael is it possible to have number of views exported as pdf (like selecting number
> of views for being exported as pdf) -I know it is possible to export pdf but is it possible
> to export multiple views at once?
Exporting multiple views on one page is not yet supported as a built in function but you can use the plug-in here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
That will generate a hidden line drawing with 4 views, and place the curves in the Top view and you can then export that to PDF.
Hi Psygorn, here's an example generated with Make2D4Views in MoI and then exported to PDF.
drawing.pdf
I upload inside Moi then export as STP
Import as multiple objects inside OnShape
and have that... top_part is the name of the entiere object!
PS
Same thing when importing as a single Object!
Export from MOI as Sat format!
Import format Sat as "single document" inside OnShape,
No problem! No error! ;)
Import your file from Moi in 3Dm format works but have some errors!
That looks promising for my needs, where can I get Make2D4Views? Is it a plugin?
-Psygorn
Aha! that's what I was looking for!
-Psygorn
Maybe there ? ;)
Make2D4Views
https://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
So for your object! ;)
For the fun... with the free Alpaca :)
As no prompt so curious result of course! :)
Just an image style...
Inside the free Vizcom who has a new version !
Automatic prompt!
and different renders
Thanks Pilou,
Thank you Michael.
-Psygorn
Else... :) Maybe not so easy than inside Moi! ;)
VIDEO
Show messages: All
1-2
3-16
