Show messages: All
1-5
6-8
Hi Guy, I deleted this current kind of patchwork of multiple surfaces:
So it looked like this:
Then I used Merge on the bottom edges so that there was just one edge down there:
Then Construct > Extrude which will now make just one larger surface going across the whole side-wall area:
Then Edit > Trim the large side-wall surface with the top edges:
Then Edit > Join to glue the pieces together.
Thank you for the workflow help!!
HI GuyLuke
我看了你的文件,并稍作尝试,将做的步骤用不同的线和名称作为注释 样式如图片并附加上制作文件,希望有所帮助(我不大懂英文,依靠机器翻译)
I have reviewed your file and made a slight attempt. I have used different lines and names as annotation styles for the steps, such as images, and attached the creation file. I hope it will be helpful (I don't understand English very well and rely on machine translation)
cam4.3dm为快速且模型为实体版本(图片soild.png)(Cam4.3dm is a fast and solid version of the model solid png))
It is also possible to separate face control points
cam3.3dm
cam4.3dm
Show messages: All
1-5
6-8
