Full Version: Point Offset Script request
Show messages: All  1-4  5-16
7 Feb 2024   [#5] In reply to [#4]
Hi Moi3dFan, please try the attached script.
Instructions for installing scripts are here:
https://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
You can click 2 points in the view to dynamically change radius, or type it in and there is a mode for generating points or for making a control point curve through the points.
Hope that is what you were looking for,
AddCornerPoints.zip
7 Feb 2024   [#6] In reply to [#5]
very useful script, thank you.
Only one question...when I select points on polylines curve and run the script error message appear "No polylines or polylines points selected" although the polylines points were selected before run the script.
If I select polyline curve as a whole script run without problem and all points are rounded.
Is it bug or I should select the points in different way?
Mik
7 Feb 2024   [#7] In reply to [#6]
Hi Mik, it sounds like a bug but I'm not seeing it over here.
Could you please post the .3dm file with your polyline in it so I can test with it?
I'm also not sure what the behavior should be for making a curve when only some corners are selected. Currently it makes a control point curve out of the whole thing with tighter bends in the corners that are getting added points.
Thanks, - Michael
7 Feb 2024   [#8] In reply to [#7]
the behaviour of script as I mentioned above is appeared in MoI V4, in V5 the script runs as you described in previous post.
Mik
AddCornerPointsTestFile.3dm
7 Feb 2024   [#9] In reply to [#8]
Hi Mik, scripting access to object edit points is new in v5 so that's normal.
You'll need to run it in v5 for that part to work.
7 Feb 2024   [#10] In reply to [#9]
It works even better than intended! Thank you!
There are a couple things that could be improved:
- Points in "Make Point" mode are added to the polyline itself. You can made checkbox for this mode.
Of course, I can cut the curve by these points and then connect them, but I want a shortcut.
- Note that, in "Make curve" mode. If a polyline has only one point selected, then after applying the script the whole polyline turns into a curve. This is rather wrong, for I want to smooth out one point.
I have a solution though - I'll just detach the corner I want and apply the script.
Thank you for taking the time to do this, with scripts like this you make it very easy to work in your favorite program
7 Feb 2024   [#11] In reply to [#10]
Hi Moi3dFan, you're welcome I'm glad that is useful.
I've updated the script (attached in message above) to have an additional polyline mode where it generates a polyline with the new points in it.
I've also updated it so that it will only smooth selected points and leave unselected ones as sharp corners.
8 Feb 2024   [#12]
And seems working even Polylines are not planar!
And multiple! :)
8 Feb 2024   [#13]
French version!
https://moiscript.weebly.com/addcornerspoints-polylignes.html
22 Feb 2024   [#14] In reply to [#11]
Greetings!
I encountered a problem, when a polyline turns into a polycurve, the script doesn't work anymore
https://drive.google.com/file/d/1u2LwGowMSEeUYyLTR0SxRHH0jSVW0hO1/view?usp=sharing
Can this be solved?
MoI_Nr1YgXqf35.mp4
22 Feb 2024   [#15] In reply to [#14]
Hi Moi3dFan,
Yes, that's correct, the script is only designed to work on polylines which is what you requested.
Making it work on other types of input would need a pretty different process, it would not be a small change to the script.
I'm sorry I'm not able to do it at this time.
22 Feb 2024   [#16] In reply to [#15]
It's ok, I found a way out by just disconnecting the corners I want and applying the script to them.
I sorry for the distraction, I hope everything is going well with your work
