Full Version: Reset view command or script
Show messages: All  1-2  3-7
29 Jan 2024   [#3]
Thank you!
30 Jan 2024   [#4] In reply to [#3]
Very useful.
Thank you.
Mik
7 Feb 2024   [#5]
Good day.
Question...I have changed to shortcut to use the script which works perfectly.
but everytime I close and open Moi the shortcut is changed back to an old command?
I use c - chamfer and changed chamfer to the new reset script.
Tnx.
7 Feb 2024   [#6] In reply to [#5]
Hi Matadem, shortcuts are saved in the moi.ini file when MoI closes.
Do you possibly have multiple instances of MoI running when you set up the shortcut?
If so then close all but one instance, edit the keyboard shortcut and then close the last instance so that it can write out settings to the moi.ini file.
If that isn't it then have you possibly set the moi.ini file to be read only?
18 Apr 2024   [#7] In reply to [#5]
You may have to resave your open template file so it saves it
