Full Version: Changing ring size
Show messages: All  1-3  4-5
14 Dec 2023   [#4] In reply to [#3]
Hi Gunter, yes that's the spot.
Some space needs to be opened up there by drawing in some cutting lines and using the Edit > Trim command to slice the ends off of the resized part, then select edges and run Construct > Blend to make a smooth blend surface and finally Edit > Join to glue the pieces together.
I've attached a model where I've done that, the steps look like this:
Draw in cutting lines in Front view:
Select resized piece and use the Edit > Trim command to cut it with the lines to open up space like this:
Select edges and run Construct > Blend to fill in the space with a connecting surface:
Ring 3.3dm
17 Dec 2023   [#5] In reply to [#4]
Michael, you're a star! Thank you so much!
Gunter
