20-34
Sorry but I have not seen the tutorial for modeling a Rolls Royce with MOI. Can you kindly provide a link?
Thanks kindly....
I have not said that : i have said Moi is the Rolls Royce of the Nurbs Modeling! :)
I you want see some cool old English cars made with Moi see MacGreggor!
http://moi3d.com/gallery/viewitem.php?id=1096
I am trying to find video tutorials of modeling cars with MOI3D AND NOT images of cars modeled with MOI3D.
I've seen plenty of images but there are hardly any videos WITH AUDIO NARRATION.
There are some video tutorials but they DO NOT have NARRATION, only CAPTIONS which I find very difficult to follow. One eye can not follow the mouse and the other eye follow the CAPTIONED text This is a very difficult task for me with my 70 year old eyes which are not as sharp as they were when I was in my 20s or 30s.
It's much easier to have both eyes on the video and both ears listen to the audio.
Cheers and thanks...
Is there any tutorials made by MacGreggor? I have seen his/her amazing works in the Gallery but no tutorial, thought u might know!
- Psygorn
No sorry MacGreggor don't make Tutorial!
except here this little one! ;)
https://moiscript.weebly.com/les-voitures-de-macgreggor.html
You can use the Google translate by address site page for any language!
You can find tutorials of car here click "original" ;)
https://moiscript.weebly.com/le-tuto-de-mauro.html
https://moiscript.weebly.com/fiat-abarth.html
https://moiscript.weebly.com/le-truck-de-ed.html
https://moiscript.weebly.com/la-voiture-de-ed.html
https://moiscript.weebly.com/la-vespa-de-mauro.html
https://moiscript.weebly.com/la-voiture-de-zarkow.html
Have fun car modeling! :)
Ps For old eyes some youtube videos by Zarkow has "general" text Captions!
Plasticity is definitely on my to buy list.
For what I do Moi is used probably 95% of the time in addition to other software.
For instance I use Vectric vcarve and it has its drawing tools...but I draw in Moi and then send to vcarve since it is way faster for me.
One thing I wish Moi had is a distort tool >
https://www.youtube.com/watch?v=-94OrLae_nY
Hi Matadem,
How is Distort different from using Flow like Michael suggested?
https://moi3d.com/forum/messages.php?webtag=MOI&msg=10114.453
If you want more than 4 control points you can do that by first drawing a grid of lines and then select the lines and do Construct > Network to make a plane. If you select the resulting plane and do Edit > "Show pts" you'll see the control points that you can then drag.
Is the problem that the result doesn't update in real time while you're dragging points?
- Peer
I hope @Zarkow will take a challenge and make his Benz using only MOI and new rebuild surface!
Tanx for the links Pilou :-)
Yep something like a realtime warp/distort would be nice.
Hi Matadem,
You can get the real-time distortion now by turning on History updating on the result of Flow. Be sure to do this immediately after doing Flow since even a tiny edit on any of the objects involved in Flow, like moving a point, will prevent history from working.
Select the objects resulting from Flow and then do Edit > History > "Enable update".
When you move edit points of the target point you should see distortion updating in real time.
History updating is turned on by default for some commands, but not for Flow. That's why you have to turn it on manually.
- Peer
I'm going to give my 2 cents here. For better or worse.
There is no software that allows me to create as fast as Moi3D. Michaels approach of finding a new approach and thinking in terms of user experience is why I finally was able to quickly create props and models without having to hand wring about edge flow and edge loops. Nothing hampers creativity than worrying about topology. I have purchased licenses for teams of artists creating previs assets for AAA videogames, all of whom now love Moi3D as much as I do.
This is me:
https://www.artstation.com/calxdesign and
http://calx.uk
Competition is what moves things forward and keeps us on our toes. The UI for Moi3D is something you barely see once you know what you're doing but if users are going to take software seriously, then it needs to look like you care.
And Moi3D looks like you don't care. It looks like you were first and don't have to.
Moi3D WAS first, but it's 2026.
Plasticity has offered a modern UI, and from what I gather is entirely misunderstood in terms of why it's gathering traction. The UI isn't required, fillets are removable and Booleans are movable, and it doesn't look like a hobby. That's enough.
Has Michaels work been built upon?
Yes.
Has Michaels work been plagiarised?
Maybe, I don't know, I'm not a lawyer.
Should it have been expected?
Yes. Absolutely.
"Let's make that Moi3D but polish the living daylights out of it and have a really slick UI and turn what he's done up to 11 and get it in front of all the YouTube influencers"
How did nobody see that coming?
I started with VU3D, then PovRay/PovCad, then 3D Studio, 3dsMAX, Rhino (YESSSS), Soft3D, XSI ... eventually Houdini for all my "geo" work, but I have never loved a piece of software as much as Moi3D, someone finally udnerstand how few fucks I give about topology when i just want to make a thing.
I'm starting to open Plasticity to get stuff done with a heavy heart because it's forward facing, not resting on it's laurels.
UI matters, UX matters. Broken Window Theory is absolutely real.
UX in NOT making things high contrast and VERY CLEAR in a big font, that's just accessibility.
I will be first in line for what comes next from Michael, and I thank you for giving me the opportunity to make, not worry about QUADS.
D.
@calx
Fillets are removable in v5 using RemoveAndFill (right click the Delete button). Faces resulting from booleans can be moved and rotated. The UI has never been required. Perhaps it's you who hasn't kept up with MoI rather than the other way around.
If what you care about is lots of black, no icons, and ALL CAPS you can do that in MoI. Check out the theme editor for a start. MoI can be customized more thoroughly than any other software I've encountered. I encourage you to transform your version of MoI into the mockup you show in order to gain some appreciation for just how well-designed the stock UI is.
Frankly, your post reads as a crude insult.
- Peer
"""Fillets are removable in v5 using RemoveAndFill (right click the Delete button). Faces resulting from booleans can be moved and rotated. The UI has never been required. """""
I was trying to come up with some type of Ludacris humor. Its as if he doesn't know?
In Reply to: Message 11209.30
"""""Its 2026!"""""
Yup. Exactly why I love MoI!!!
BTW. That image posted? That's got to be the ugliest thing I've ever seen! It looks like a novice loaded up a free download called "Web UI Maker" and output some kind of default Nonsense and hit "Generate". I'm surprised it doesn't say "Lorem Ipsum" Somewhere on the screen....
Please stop.
Aside from entirely unconstructive criticism, lacking any actionable advice or feedback, your reply demonstrates a purely tribal love for a piece of software because of...the date? I'm not sure you've contributed much here, but thanks.
For the record Lorem Ipsum is dummy text, it is invaluable in communicating the typographical intent of the designer without the user being distracted by the contents of the text. Which is apparently something which was also lost on you.
This was a 2 year old thread so just gonna lock it.
20-34
