Full Version: Trouble exporting paths for gradient filling in other vector software
Show messages:  1-4  5-24
8 Jul 2023   [#5] In reply to [#4]
Yes, It is a closed curve. It is created by freeform.
8 Jul 2023   [#6] In reply to [#5]
closed curves or not from MOi are present in Affinity :)
Of course these are "projected on a plane" of your 3D drawing from MOi!
8 Jul 2023   [#7] In reply to [#6]
The AI file format is an Adobe Illustrator format, right?
I figured since I have the output in AI, I could pass along the information that makes up the path.
I am trying to do something like this.
What I am dealing with is 2D path information.
8 Jul 2023   [#8] In reply to [#7]
8 Jul 2023   [#9] In reply to [#7]
You can make the same than your "M" with the PDF format more versatile! ;)
8 Jul 2023   [#10] In reply to [#9]
PILOU, thank you. I did it.
I didn't think it was possible to pass the path info in PDF.
I've only tried it in simple shapes, but I think it will allow me to do what I want to do. :)
8 Jul 2023   [#11]
8 Jul 2023   [#12] In reply to [#7]
Hi marzRX,
The AI format written from MoI is for an older version of Adobe Illustrator which isn't supported by either Affinity Designer or Inkscape.
So for export to those programs use PDF format instead, AI and PDF are similar and each can contain path information in them.
Also the v5 beta (https://moi3d.com/beta.htm) adds support for SVG format which is probably the best for transfer to Inkscape.
9 Jul 2023   [#13] In reply to [#12]
Thank you, Michael.
This is the first time I learned that a PDF can hold path information like an AI file. I'm looking forward to version 5.
By the way, when creating logos, I often need to align the center of the reference image with the center of the grid.
It would be very helpful to have an option or a snapping feature to automatically make this alignment.
9 Jul 2023   [#14] In reply to [#13]
Maybe like that ?
9 Jul 2023   [#15] In reply to [#14]
Yes, When positioning the image, a message saying "pick image base point" is displayed.
At this point, unless the mouse snaps to the center of the image,
I have to manually select a point near the center. However, this might not be accurate.
While some images make it easy to identify the center, this is not always the case.
Even if there is no snap feature available, having a cross line drawn on the image like the one shown in light blue this time can be helpful.
9 Jul 2023   [#16]
Use the construction lines (and its Mid point) as in this example with align function of image.
Is this the result you wanted ?
9 Jul 2023   [#17] In reply to [#16]
Very cool! ;)
More precise than i made on the fly on the 3D view! :)
(not shown on the video just a try because there is no snap for helper lines on the corner image in 3D space... ;)
9 Jul 2023   [#18] In reply to [#13]
Hi marzRX,
When you are in the View > Image command, you can drag on images to reposition them and if you start the drag by grabbing near a corner or the center it will snap on to those as the base point for the move.
You'll see a tag appear like this:
9 Jul 2023   [#19] In reply to [#15]
Hi marzRX,
The "Align" function is for a different purpose, to map a line in the image with a line in model space.
For what you want, don't go into the Align sub-tool just drag starting from near the center while you are running in the Image command.
9 Jul 2023   [#20] In reply to [#19]
Thx for the info! Edgar Poe stolen letter syndrome :)
9 Jul 2023   [#21] In reply to [#16]
Hi Phiro,
When I saw your answer, I realized that I had overlooked the construction lines.
However, when I actually tried it, it didn't work well.
Do the construction lines snap to the corners of the image?
In your video, you're dragging the image right after drawing the construction lines. Did you edit that part? I tried to replicate it but couldn't do it as smoothly as in your video.
I tried to replicate your procedure. It's not snapping to the corners.// 450KB mp4 attached
logo_center_construction.mp4
9 Jul 2023   [#22] In reply to [#21]
Hi marzRX, some info above here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11144.18
http://moi3d.com/forum/index.php?webtag=MOI&msg=11144.19
Don't use the Align tool, instead drag the image from the center point while running inside the main Image command, not the Align sub-command.
9 Jul 2023   [#23] In reply to [#18]
Wow! I would never have noticed that.
Whether it's exporting paths or center snapping for images, it turns out that all these features were included - I just didn't know it.
I guess I need to study a bit more. Still, I'm happy to find out that I can do what I've been wanting to do. Thank you. :)
9 Jul 2023   [#24] In reply to [#22]
Got it! I just need to drag from the center point while within the main Image command, not the Align sub-command.
It took me a bit longer to respond as I was writing in English.
