Full Version: Scripting and Node Editor in Moi3D V5
Show messages:  1-19  20-28
16 Jun 2023   [#20] In reply to [#13]
There is no case for Nodeeditor, I am very interested in Nodeeditor modeling
16 Jun 2023   [#21] In reply to [#20]
Hi c3g, there is some information on the node editor here: https://moi3d.com/wiki/nodeeditor
12 Jan 2024   [#22] In reply to [#15]
Hi Forum. On Ubuntu using Wine following these directions I'm unable to relocate node editor to "/home/sven/.wine/drive_c/users/sven/AppData/Roaming/Moi" (assuming "I" in original post is a mistake). It does work in "/home/sven/.wine/drive_c/Program Files/MoI 5.0 beta Dec-1-2023/ui". Can sombody confirm this should work as posted ?
Sven
12 Jan 2024   [#23] In reply to [#22]
Hi Sven, if you put it in "/home/sven/.wine/drive_c/users/sven/AppData/Roaming/Moi then to launch it you would need this in your shortcut key:
script: moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
If you put it inside /home/sven/.wine/drive_c/Program Files/MoI 5.0 beta Dec-1-2023/ui then the script to launch it is slightly different the URL starts with moi://ui instead of moi://appdata like this:
script: moi.ui.createDialog( 'moi://ui/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
12 Jan 2024   [#24] In reply to [#23]
Hi Michael. Confirming your paths and copying & pasting your scripts from your reply it still works via the ui directory, but NOT the appdata directory.
Sven
12 Jan 2024   [#25] In reply to [#24]
Hi Sven can you please post the node editor .zip you're using and maybe show a screenshot of where it is installed in appdata?
Thanks, - Michael
13 Jan 2024   [#26] In reply to [#25]
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1 is the link from https://moi3d.com/wiki/Nodeeditor#Installation
Sven
13 Jan 2024   [#27] In reply to [#26]
Hi Sven, ok so it's because when you're running on Linux/Wine the appdata folder for MoI is at ~/.moi instead. Does it work if you put it there?
15 Jan 2024   [#28] In reply to [#27]
Yes Michael. That does the trick, thanks for the clarification.
Sven
