Full Version: AutoHotPie
Show messages:  1-8  9-24
22 Feb 2023   [#9]
I progress! All classic UI is done!
Now just to add the commands! :)
22 Feb 2023   [#10] In reply to [#9]
Amazing! :)
Great job!
1 Mar 2023   [#11]
Find the complete process for all scripts ! :)
If a script is an oneline script save it as a named .js file
For the rest...who are not "one line"
Rename _Voronoi.js to sVoronoi.js
and _Voronoi.htm to sVoronoi.htm
Like this all can be called by the Send Key Function / Add Stroke Key!
Ps don't forget to modify your shortcuts board if you have not make a copy with a different name!
Just find 150 icons si absolute necessity! :)
1 Mar 2023   [#12] In reply to [#11]
Amazing job!
5 Mar 2023   [#13]
Ok I have finished! you can download it bottom page!
https://moiscript.weebly.com/autohotpie.html
5 Mar 2023   [#14] In reply to [#13]
Amazing job!
I definitely want to try it out but...it seems to be a Windows only version.
Does it work on MacOS? And, if so, how to install and make it run on Mac with Moi3D?
5 Mar 2023   [#15] In reply to [#14]
I am affraid that is only for Windows! Maybe with an emulator for Mac...
6 Mar 2023   [#16] In reply to [#15]
Ok. Thanks.
Pity!
Ciao :)
8 Mar 2023   [#17]
Complete French Tutorial AutoHotPie / Moi3D
Final Moi3D-AutoPie in English! The French one in few times!
8 Mar 2023   [#18]
I have used the mode 4! Free to you to take another one! ;)
Mode 4
10 Mar 2023   [#19]
English version is working fine! :)
some Scripts included! (not shown here)
https://moiscriptlweebly.com/autohotpie.html
14 Mar 2023   [#20]
English & French version done! :)
Only one shortCut to remember! "X" ;)
https://moiscript.weebly.com/autohotpie.html (Bottom page)
12 Apr 2023   [#21]
Nice! I am not speaking French, so must be missing some details. I have everything installed and can create my own menus, but not sure how to install the pie menu you created.
edit:
nvm, I found that you need to "import settings" in Autohotpie and direct this to the AHPSettings.json that you have so kindly provided. This will load your pie menus, which can then be modified as the user wants.
Awesome! Thanks again for your wonderful contribution.
12 Apr 2023   [#22] In reply to [#21]
Tell me if that is working fine for you! (the English version! ;)
Don't forget to add the 2 files (commands & scripts) if you want all that is in Pies!
And remember Launch AutoHotPie
then green Button Save & Run (always in AutoHotPie)
Then launch Moi3D
then "X" if you want call AutoHotPie inside Moi3D
Esc for normal mode, "X" again for recall it in the same session etc...
12 Apr 2023   [#23] In reply to [#22]
yeah, all that works.
Just some instructions missing, likely because you built the script and didnt need to follow those steps, but if a user downloads your content, they have to follow additional steps.
After installing:
1. import settings file that you provided (this will delete any previous settings and menus)
2. import custom icons through Autohotpie GUI (drag and drop wont work)
12 Apr 2023   [#24] In reply to [#23]
Cool and thanks for the complement of infos!
