Full Version: Trim command behavior options
Show messages:  1-8  9-28  29
23 Jan 2023   [#9] In reply to [#8]
No problem i had saved it in case of! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/unexpectable_result.3dm
23 Jan 2023   [#10]
The concept and video are great, but, on my M1 Mac Studio it acts a little kooky. After swiping across the curve to trim away I get a 'beachball' for maybe 15 seconds and then every intersecting line on the entire model is 'broken' by inserting a point at the intersection- another 10 or 15 seconds and the section I wanted trimmed is gone. So, the curse of the Mac strikes again. I wish I could capture the model at the point where all of the intersecting lines are broken into separate segments and just run around the model deleting all of the segments I want to trim, but I can't do anything once the beachball and point insertion process starts.
It's so close to amazing- if I could forget about swiping and get MOI to temporarily insert a point that breaks every line at an intersection I could delete the offending line segments in no time.
Again, it's so close to being a technical illustrator's dream function. In case you don't have a silicon Mac I can make a screenshot of the intermediate step, where points are inserted at every intersection throughout the entire model.
Thanks for the effort,
Rick
23 Jan 2023   [#11]
This is what I see after swiping across 1 line segment- it does delete the segment. I would like to work on the drawing at this stage- it would be so easy to just move around deleting the bad segments.
23 Jan 2023   [#12] In reply to [#11]
Hi Rick,
Have you tried out the Virtual Segment Delete tool in CorelDraw? https://www.youtube.com/watch?v=3nwKVFKy-4Q
23 Jan 2023   [#13] In reply to [#11]
Also, I've had good luck with the Hatchet plugin for Illustrator when I need more control than virtual segment delete https://rj-graffix.com/product/cutting-tools-plugin/
23 Jan 2023   [#14]
Peer,
Thanks for the suggestions, I haven't used CorelDraw this century- didn't know it was still around, but that tool looks really useful. I've had mixed results with third party Illustrator plugins- not working over OS upgrades, Adobe updates, etc- I'm trying to like Affinity Designer, but it's not going well- just selecting a curve is too hard, and no LivePaint makes it too time consuming to use.
I really like 2D drawing and editing in MOI, so I export to illustration apps as a last resort. If/when MOI can make trimming faster I'd do 99% of a drawing in MOI.
Calling a Trim command and having it trim a selected line to intersections without clicking the cutting line and the segment to be deleted would be ideal, maybe with the option to delete or keep the new segment.
For me, bouncing back and forth between programs with all of the translations involved is slower than just struggling through- maybe Michael will come up with a solution.
Rick
23 Jan 2023   [#15] In reply to [#8]
“””””” So with regular Trim if there is an intersection only at one end of the curve it won't be targeted. QuickTrim then inherits that same behavior from regular Trim.
Maybe I can get it set up so that QuickTrim will work for that case though.””””””
That seems like the behavior i’d expect from your ”Eraser” tool once you get click and drag implemented.
23 Jan 2023   [#16] In reply to [#9]
Thanks, that was a bug where the "curve from 2 views" mechanism in the Intersect command was causing some 3D curves to be targeted by a swipe when they shouldn't be.
I've uploaded a fixed version, this one should now ignore this case instead of mistakenly targeting 3D curves.
Thanks, - Michael
23 Jan 2023   [#17] In reply to [#10]
Hi Rick,
This likely has more to do with your particular model than being on Mac, can you please send the file to me at moi@moi3d.com so I can test with it?
One problem that I just fixed now is that it was trying to process hidden curves instead of skipping them.
Also I've updated it so that it only tries to intersect curves that are on the same plane as the swipe, that should help with performance.
Thanks, - Michael
23 Jan 2023   [#18] In reply to [#16]
Cool!
But seems this is not the same behaviour of the Trimer...
Now it is like a Polyline and not a curve!
Does this normal ?
23 Jan 2023   [#19] In reply to [#18]
> Does this normal ?
Turn off grid snap in the bottom toolbar.
23 Jan 2023   [#20] In reply to [#14]
@Rick - thanks for sending the file through e-mail.
So just so others see this as well the slowdown issue is trying to use QuickTrim directly on your model with 3296 curves.
That will do the equivalent of using the regular Trim command and selecting all 3296 curves as both the objects to be cut and also as the cutting objects.
To solve this you'll need to narrow down the number of candidates that QuickTrim will be trying to process.
You can do that either by hiding curves outside of a current active working area of say a few hundred curves or by selecting curves in a particular area. If you have some selected curves the cutting up processing will only happen on that selection.
Maybe someday I can work on this to make a large several thousand candidate pool work better but that won't be anytime soon. To use it effectively you will need to narrow it down to something like 2 or 3 hundred curves or ideally even less rather than several thousand all being active on the same operation.
Thanks, - Michael
23 Jan 2023   [#21] In reply to [#19]
Ok!
And the Trimer works only on curves and not on Lines ?
23 Jan 2023   [#22] In reply to [#21]
It works on lInes, but only if the line is being cut up into some pieces. It currently won't remove a line where the line only touches other things at its endpoints instead of being cut somewhere inside the line.
It will be able to do that in the next v5 beta release, it needs an adjustment in the Trim command factory to also target those cases.
23 Jan 2023   [#23] In reply to [#22]
Thx for the Infos!
20 Feb 2023   [#24]
Nice feature !
It could be interesting this kind of "draw to select" feature could apply on the regular selection behavior.
Perhaps with a modifier key ?
Marc
19 May 2023   [#25]
I'm happy to report that my initial post wasn't the result of hallucination- there is a way to streamline trimming but it uses the EXTEND command instead of TRIM- sounds kooky, but it works. Click on a line you want to trim on the side you want to keep, call the EXTEND command and click on the line you want to trim to and the excess line is gone- click away to clear the selection and trim again- the EXTEND command remains active. This is the behavior I originally asked about but couldn't recreate since I was using the wrong command. This method sometimes fails if the line to trim to offers a possibility to actually extend, but most of the time I'm trimming to a line that doesn't have an EXTEND option- can't explain why it trims correctly to a line through a circle, but I don't know what's going on in the code. After trimming this way for while it becomes really efficient- I make 2D drawings using MAKE2D and often have hundreds of lines the run on too far and trimming with EXTEND makes cleaning up a drawing much faster- for me at least.
Rick
MOI extend trim.pdf
20 May 2023   [#26]
Tricky!
20 May 2023   [#27] In reply to [#25]
Hi Rick,
That's some interesting undocumented functionality you discovered! It also looks like both curves can be trimmed in one go with "mutual extend" by selecting both curves, calling Extend, and clicking Done.
Re:
Do you mean that you're tapping Enter on the keyboard to repeat the Extend command? I don't see the Extend command remaining active, but I can repeat it by tapping Enter like for all other commands.
I went back and read your posts from a few months ago and am thinking there might be a better way though...
Re:
> starts. It's so close to amazing- if I could forget about swiping and
You can do exactly that already with Trim by doing a "mutual trim" where you select everything, run Trim, and then click Done.
http://moi3d.com/4.0/docs/moi_command_reference4.htm#trim
But, like you ran into with the QuickTrim plugin, there might be some spinning beach ball for a little while. I just tried doing mutual trim on a drawing with 4700 curves and that took about 23 seconds to insert the temporary break points. But, doing 1200 of those curves only took 2 seconds.
Since mutual trimming bogs down with large numbers of curves it's probably a good idea to work on one section of a drawing at a time like Michael suggested. An easy way to do that is by selecting all the curves that cross an area using a right-to-left area selection box and then run Trim. Fragments to remove can be selected in groups with left-to-right area selection.
Re:
> segment.
A plugin could be made along these lines, but what would the advantage be vs mutual trim? It could get around the performance issues when there are thousands of curves, but working on one area of a drawing at a time also does that.
Re:
Are you talking about problems with hidden line generation where a line that's visible but that disappears behind a solid object doesn't end exactly where it should? Are you running V5 beta Apr-13-2023? Michael made some pretty significant improvements to hidden line generation in the recent betas. Still not perfect especially on threads, but might save you quite a bit of work if you're not already using it.
Also, turning up the Resolution of make2d might help minimize the length of the line overshoots. The default is 25, but cranking it up to like 200 will make the overshoots a little shorter. Resolution of 200 requires having about 10 GB of RAM available.
- Peer
21 May 2023   [#28] In reply to [#27]
Peer,
I can't thank you enough for pointing out what was right in front of me all along- the TRIM/MUTUAL option is exactly what I wanted- breaking a group of lines at every intersection. I regenerated some MAKE2D files, and cleaning them up is much easier- thanks again.
Rick
