Full Version: Updates to the MoI API of David C Morrill
Show messages:  1-9  10-29  30-49  50-53
12 Oct 2024   [#50] In reply to [#49]
Hi Brian, I reformatted the code block, is that ok now?
12 Oct 2024   [#51] In reply to [#50]
Thank you Michael.
Most of the code block is correct, but the two "table" code lines need to be removed.
(The lower "table" line is in the correct position, but the upper "table" line is many lines further up in the SidePane.htm code.)
I think that my mistake was failure to use the correct code block symbols initially, posting, and then trying to edit in the corrections. (?)
12 Oct 2024   [#52] In reply to [#48]
Thanks for pointing out the typo. It's been fixed and various new curve methods have been added. See post above for files
https://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
- Peer
14 Oct 2024   [#53] In reply to [#52]
Thankyou Peer, for your work!
