9-28
29-48
49-53
Well, the edit function for the previous post quit working.
The code block does not like some symbols, and half of the code block disappeared.
Maybe just delete the "BlueFlask" portion of the post?
Hi Brian, I reformatted the code block, is that ok now?
Thank you Michael.
Most of the code block is correct, but the two "table" code lines need to be removed.
(The lower "table" line is in the correct position, but the upper "table" line is many lines further up in the SidePane.htm code.)
I think that my mistake was failure to use the correct code block symbols initially, posting, and then trying to edit in the corrections. (?)
Thanks for pointing out the typo. It's been fixed and various new curve methods have been added. See post above for files
https://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
- Peer
Thankyou Peer, for your work!
9-28
29-48
49-53
