Full Version: Sugarloaf Cabochon ?!
Show messages:  1-2  3-22  23-33
20 Apr 2022   [#23] In reply to [#21]
Thank you Disovered lots if scripts at the link you posted and will give them a try.
20 Apr 2022   [#24] In reply to [#23]
Hi Tom,
Brian is the creator of these scripts. He has made several of the "mathematical formula" scripts that create well known geometrical shapes.
He is best to answer about them and if there is any difference (or similarity)
20 Apr 2022   [#25] In reply to [#24]
Since this impossible word "Squircle" nauseated my mind it mixes up the names Burrmen Benfarmer and Brian -sorry ;-)
20 Apr 2022   [#26] In reply to [#25]
Hey Tom... makes it harder to have to translate everything. Hang tough!
"Squircle"
Square + circle
Squ ircle
20 Apr 2022   [#27] In reply to [#20]
... another elegant way
Mik
Isect 2D curves.3dm
20 Apr 2022   [#28]
This link shows a side view of a cabochon:
https://www.rockngem.com/filling-an-empty-space-and-enhancing-a-cabochon/
I had thought that it is a sugarloaf, but now think it is a "slab" for a pendant. ?
Learned a new word: "vug"
https://en.wikipedia.org/wiki/Vug
image host
20 Apr 2022   [#29]
Very nice Mik
23 Apr 2022   [#30]
Due to your kind collaboration this thread turned into a nice
compilation of how to achieve one goal by different means -
thank you all !!
As one contributor wrote, the shape of a "squircle" is aesthetically
very appealing. I wanted to apply this theme of "squaring the circle"
to the whole shape, starting with a circle at the bottom morphing
into a slightly rounded square at the top. The how to is attached
below.
24 Apr 2022   [#31] In reply to [#30]
Cool result! :)
24 Apr 2022   [#32] In reply to [#30]
Reproduced a close copy of Toms cab, using his images to reproduce curves.
Note that the two "acorn" shaped curves must be trimmed apart at the North and South poles, into 4 curves, for network to work. (Or kept separate during their creation.)
One-half "acorn" curve was created with two blends. A horizontal line segment was placed at the North pole, and a vertical line segment was placed at the squircle intersect point, and a blend done between. A second blend was done from said curve, down to a horizontal line segment at the south pole. Join for one curve.
Mirror and rotate for other 3 acorn half curves.
Rounded square, squircle, and lower circle curves were also created. The lower circle had to be a bit larger than the sketch IMHO.
Select all 7 curves, and do network.
Still attempting to load my old purchased copy of Keyshot 6.
25 Apr 2022   [#33]
I attached my approach to the profile curve - MOI works so great
for stuff like that.
