Full Version: Convert model from perspective to front view
Show messages:  0-19  20-31
20 Mar 2022   [#1]
Hello.
So I have this 'normal architectural model', and I need to turn it into a 'front ortho view' model but retain the 'perspective feel' still intact. Maybe the best way to describe is: I need to make a relief image out of this model. (https://en.wikipedia.org/wiki/Relief), so that the final model will be a relatively flat (boxy) 3d model.
This will be printed as a relief-like souvenir, but not a miniature one. I really hope I make myself clear.
Now what's the best way to do it?
20 Mar 2022   [#2] In reply to [#1]
Hi Elang, you could export to DXF format and then import that back into MoI.
There is also a command named "Make2D" that can make a 2D projected drawing from your 3D model. You can run that by typing Tab then type make2d and hen push the Enter key.
20 Mar 2022   [#3] In reply to [#2]
Hi Michael, thank you very much for your quick reply and I've tried your suggestion.
The thing is: I need this model to stay 3D instead of 2D vectors. So that I can 3D print it as a relief piece like the following picture.
The output 3D file needs to be in OBJ.
Thank you very much in advance.
20 Mar 2022   [#4] In reply to [#3]
Hi Elang, in general the accurate structured geometry that CAD programs like MoI work with is not very suitable for that kind of relief model shaping.
Something like ZBrush or 3D-Coat works better for that kind of model. Also take a look at Vectric Aspire: https://www.vectric.com/products/aspire .
20 Mar 2022   [#5]
Thank you very much, Michael.
21 Mar 2022   [#6]
If I understand, you want to have a relief of your model.
A possible way could be to render the model with depthmap shader in meshLab (or perhaps another software) and next using this image as a heightfield map to do a relief 3D model.
21 Mar 2022   [#7]
Hi Pilou.
Yes that's exactly what I need. Can you please post the link for the tutorial from start to finish? I have the heightmap already...
Thank you in advance.
21 Mar 2022   [#8] In reply to [#7]
Hi Elang,
in ZBrush you can follow this steps
http://docs.pixologic.com/user-guide/3d-modeling/sculpting/bas-relief/
Sometimes is it hard to get a clear and clean mesh from a 3d package to ZBrush. So make sure the mesh ist a solid, the normals showing in the right direction
Another solution can be:
Export this model as obj and import it to Cinema 4d and use the Volume Builder and the Volume mesher to generate a volume.
This solution is more flexible, but it can be need a lot of ressources of your hardware. Try first with a bigger voxel size!
https://www.youtube.com/watch?v=H-cykUwp4yU
22 Mar 2022   [#9]
Hi Pixelhouse,
Thank you very much for the info. I'm not a native English speaker so it's quite hard to determine the right keywords/terms for googling. I'll make it sure to check them out.
Cheers!
22 Mar 2022   [#10]
Sorry, I don't have a link on a tutorial to create an heightmap from a model.
It's only a possible workflow I found for your need.
I think it's possible with Blender to have a depthmap, but I haven't learned Blender yet.
So...
1/ you can export your model as STL file. Perhaps OBJ is OK too.
I don't have you file and took for the example a very old model of saloon, I made 30 years ago .
2/ import this mesh in the Meshlab program. You can find it here : https://www.meshlab.net/
3/ you go in the Tools/options menu to parameter the background top and bottom with white.
4/ in View menu, verify the options to avoid trackball and info Panel
5/ In the Render/Shaders, use the DepthMap shader.
Tune the sliders to have a grayscale.
6/ take a screenshot of the zone you want
7/ use your favorite bitmap editor to invert the colors.
The Moi's plugin to use heightmap use black to white grayscale.
8/ In MoI, use the heightmap plugin to have a serie of profiles
9/ use the Loft tool (using all the profiles) to create a relief.
It's not very orthodox use of MoI.
Apologies to Michael, the spirit of MoI is here deflected...
22 Mar 2022   [#11]
Hi, Phiro.
Thank you very much for your effort to post the quick but super useful tutorial.
Appreciate it very much. This forum is great!
22 Mar 2022   [#12] In reply to [#1]
Hi Elang,
So with the different "types" of relief, you can go 2 routes. For "3d printing" i think you want to stick with "low relief" or bas relief.
For this you would use a program that can generate an "emboss" from a bitmap, 2d graphic. There are various methods. All the way down to just screenshoting your model. Poly modeling apps and cnc CAM apps usually have this ability
I think you can generate a somewhat "ok" model as a "high relief" inside of moi. But a high relief will not be great for 3d printing with regard to all the undercutting. If you wanted to take the time, you could probably "fix" the major undercut areas, for a 3d print.
To do a high relief in MoI, i would "rotate the model" to get the perspective you need in one of the flat views, then use the edit frame to flatten the model to the desired height.
I'll see about making a video to demonstrate the 2 options.
22 Mar 2022   [#13] In reply to [#12]
Hi Burman, thank you for your help. Definitely waiting for the videos.
However, I've tried rotating the model in the front view, but since it is ortho view, I can't get the perspective as it is needed. Is there something I'm missing here?
22 Mar 2022   [#14]
By the way, since it is a hobby project, please allow me to share the 3DM model.
It's not the best model, however. Some parts are still surfaces instead of solids.
Gedung Dakwah.rar
25 Mar 2022   [#15] In reply to [#14]
Hi Elang,
I think this is what you were looking for? I included the 2 scripts I used to make your perspective view a flat 2d workplace. Then Flattened the model to 2 units.
There is a bit of lag on some operations because I have my viewport mesh settings very high and the model is not a simple one.
I was a bit sloppy on rotating the flattened perspective back to a regular 2d view, but you could be more precise if you need.
I can show you a regular Bas Relief emboss in some other software if you need to see that.
Hope it helps.
perspective_to_flat.zip
26 Mar 2022   [#16] In reply to [#15]
Hi Burman
Thank you very much for your effort in making the video. Appreciate it very much!
The thing is: in the final result (front view), the building has 'the same height' from left to right, while for it to be seen as 'correct in perspective' the leftmost part should be somewhat shorter than the right one. I tried to do it the same way as your video, followed by flow-deform it from a rectangle to a trapezoid. But it gave me an unexpected result (and took quite a while to process).
So I decided to simulate it with a simple circle, and here's what I got.
1. Choose the circle
2. Apply Deform > Flow
3. Pick the upper right corner of the square as 'base curve'
4. Pick the upper right corner of the trapezoid as 'matching end'
I don't use deform quite often so surely I'm the one who's mistaken.
^_^;
26 Mar 2022   [#17] In reply to [#16]
Hi Elang,
"""""""The thing is: in the final result (front view), the building has 'the same height' from left to right, while for it to be seen as 'correct in perspective' the leftmost part should be somewhat shorter than the right one. """"""
Ah, i get it....
Not just a perspective emboss or relief but the model itself to actually be skewed.
I'll see if i can do that result in a bit.
26 Mar 2022   [#18] In reply to [#17]
So maybe this....
I have included the 2 surfaces i used to flow. you can just copy and paste them or import into your model to be ready for flow.
Select model. then flow from square to perspective shaped surfaces.
I am not a projection specialist. The "Perspective surface" was created by me by drawing the lines. Maybe Michael or someone who is familiar can discuss drawing the trapezoid shape as an exact "Perspective".
flow surfaces.zip
26 Mar 2022   [#19] In reply to [#18]
For your flow issue. I dont think it likes a closed curves for a curve to curve flow.
You can create surfaces in that condition.
A simple planar surface wont work here. you need to make a surface with some parameters. I used sweep to generate the 2 surfaces I have attached. Turn on points for those surfaces to see the difference between a planar surface and a swept surface.
26 Mar 2022   [#20]
Hi BurrMan.
Thank you very much!.. I'll check out and study the file you've attached soon.
Sincerely.
