Full Version: Wacom Pen Delay | Orbit & Pan
Show messages: All  1-2  3-9
13 Jan 2022   [#3] In reply to [#1]
Hi Berube, is there any difference if in moi.ini you set ObjectSnapShowMarkers=n ?
I set up a Wacom tablet over here with Monterey OS on an M1 MacBook Air but I'm not seeing anything like you're describing.
26 Jan 2022   [#4]
Hello Michael,
Thank you for the reply.
I did try what you suggested and it does not make any differences at this time.
-Berube
26 Jan 2022   [#5] In reply to [#4]
Hi Berube,
What method are you using for doing the Orbit or Pan, are you clicking inside the viewport and dragging with a pen button down? Or using the buttons at the bottom of a viewport? Or using a modifier key like Alt?
Right now I am not able to reproduce this problem and I will need some more details from you to have any chance at figuring out what might be wrong.
27 Jan 2022   [#6] In reply to [#5]
Hello Michael!
Thanks for the reply. Awesome. Ok I did some digging to try to isolate the problem.
I am navigating the viewport using a Wacom pen, only via clicking inside the viewport using Alt and a combination the left, middle and right click.
I just noticed Orbiting is nice and direct. No issues there!
Only Panning (Alt + Middle Click drag) and Zooming (Alt + Right Click drag) have the delays.
I tried the same combination of navigation moves in Blender 3D and did not see an issue. Which rules out a Wacom Driver issue.
I made screen recording that demonstrate what I see on my side. It almost looks like a screen registration zone.
https://www.dropbox.com/s/53hizaet4fdo8wv/moi-panning-zooming-delay.mov?dl=0
Let me know what you think!
-Berube
27 Jan 2022   [#7] In reply to [#6]
Hi Berube, thanks for sending the video, that helps me understand.
That happens because MoI does different things in some cases when you do a press and release (click) versus when you do a press and drag.
When you initially click down, MoI will go into a kind of "wait and see" mode where if you release the button it will do a click action or if you move the mouse far enough with the button still down it will do a drag action.
But for the Orbit with Alt+Left drag, there isn't anything that happens with a click so it will go into directly into view manipulation without any "wait to see if it's a drag or click" happening.
You should get the same immediate behavior for Pan and Zoom if you use Alt+Shift+Left drag for pan and Alt+Ctrl+Left for zoom instead of using middle or right buttons there.
The behavior with Alt+Middle and Alt+Right has been like this since MoI v1, it isn't any recent change in v4.
But I think I should be able to set Alt+Middle and Alt+Right to behave like Alt+Left though since there isn't anything special happening for a click versus drag there so the "wait to see if it's a drag or up" step should be feasible to skip there as happens for Alt+left currentlly.
I'll see about setting that up for the first v5 beta.
27 Jan 2022   [#8] In reply to [#7]
Hello Michael,
Thank for the very thorough answer. Very good.
I can confirm that using Alt+Shift+Left gets rid of the delay. Nice and zippy. Great to see!
I've been navigating in multiple 3D software for so long that re-wiring my muscle memory will be hard.
It's also because I use multiple 3D packages all at the same time, I want them to have all the same navigation controls so the creative process is seamless.
Is there something I could modify in the .ini file to eliminate the "Wait and See" item?
Thanks for the legendary customer service. Seriously.
Best,
-Berube
27 Jan 2022   [#9] In reply to [#8]
Hi Berube,
Sorry no there isn't anything currently set up that can modify that particular behavior.
I'll get it tuned up for v5 though and I hope to get going with v5 betas soon.
