Full Version: Zoom all quad views in or out at once
Show messages: All  1-5  6-11
9 Jun 2021   [#6]
Hello Michael,
Is this possible in Options (zoom independent and together) and also a short-cut?
Thank you.
9 Jun 2021   [#7] In reply to [#6]
HI Carlos,
There is an option under Options > View > Rotate/Pan/Zoom options > "Link ortho views" which will keep the Top/Front/Right views to be all at the same zoom level. When that is enabled if you zoom in the Top view for example, the Front and Right views will also update.
Is that what you were asking about or is it something different?
9 Jun 2021   [#8] In reply to [#7]
Wow, that's a useful hidden option I hadn't discovered yet, thanks Michael!
11 Jun 2021   [#9]
Yes, but be able to turn it off/on with a short-cut?
Thanks.
11 Jun 2021   [#10] In reply to [#9]
Hi Carlos, you can set up a shortcut key to toggle the "Link ortho views" option on or off with this:
script: /* Toggle link ortho views */ moi.view.linkOrthoViews = !moi.view.linkOrthoViews;
14 Jun 2021   [#11]
Thank you Michael.
