Full Version: Zoom all quad views in or out at once
4 Jun 2021   [#1]
Hi Michael et al,
I was wondering if it would be possible to zoom all viewports in or out at the same time, with one zoom gesture?
I often focus on an object using script: moi.view.resetAll(); and then like to see some surrounding space in all views.
Thanks!
4 Jun 2021   [#2] In reply to [#1]
Hi Metin,
Try setting up a shortcut key with this script on it:
script: /* Zoom all viewports out a little */ var vnames = [ 'Top', 'Front', 'Right', '3D' ]; for ( var i = 0; i < 4; ++i ) { moi.ui.mainWindow.viewpanel.getViewport(vnames[i]).zoom( 1.1 ); }
4 Jun 2021   [#3] In reply to [#2]
Great, thanks for your service Michael!
Enjoy your weekend!
5 Jun 2021   [#4] In reply to [#2]
and anything below 1 in zoom( x ) field will zoom in! The closer to 1, the smaller the zoom increments. (for example zoom( 0.9 ) )
I have no clue about scripting, but I just tampered with it like a monkey in a spaceship lol
5 Jun 2021   [#5] In reply to [#4]
Haha, nice to know, thanks!
9 Jun 2021   [#6]
Hello Michael,
Is this possible in Options (zoom independent and together) and also a short-cut?
Thank you.
9 Jun 2021   [#7] In reply to [#6]
HI Carlos,
There is an option under Options > View > Rotate/Pan/Zoom options > "Link ortho views" which will keep the Top/Front/Right views to be all at the same zoom level. When that is enabled if you zoom in the Top view for example, the Front and Right views will also update.
Is that what you were asking about or is it something different?
9 Jun 2021   [#8] In reply to [#7]
Wow, that's a useful hidden option I hadn't discovered yet, thanks Michael!
11 Jun 2021   [#9]
Yes, but be able to turn it off/on with a short-cut?
11 Jun 2021   [#10] In reply to [#9]
Hi Carlos, you can set up a shortcut key to toggle the "Link ortho views" option on or off with this:
script: /* Toggle link ortho views */ moi.view.linkOrthoViews = !moi.view.linkOrthoViews;
14 Jun 2021   [#11]
Thank you Michael.
