Show messages: All
1-4
5-8
OK, so your reasoning is that because it is complicated it won't happen in MoI?
Alibre Design has no problem with it - see screenshot. Because Alibre Design is parametric it's less of an issue there than in MoI because I could just swap the order of operations around. With MoI not being parametric (understandable) it becomes more important IMO for the application to do what the user expects as it may be very difficult to undo multiple steps and change the order of things (e.g. shell before fillet).
An added complexity for MoI is that it forces the user to consider the order of things depending on the values used, for example:
Wall thickness = 3mm, fillet = 5mm : do fillet then shell
Wall thickness = 6mm, fillet = 5mm : do shell then fillet
Andy
Andy -
Just my $0.02 worth of experience:
I try to avoid fillets on simple shapes because yes, they are difficult to un-do. Instead I'll first try to build the fillet into the construction curves.
In the case of the capped, shelled cylinder, you can draw a 2D profile curve, apply the 2D fillet, and Rail Revolve into a cylinder having a thick wall. The advantage is you can simply move a couple of points and re-do the Revolve to get a new fillet dimension.
I also tend to save making fillets to the very end of the model creation so I don't paint myself into a corner.
Another thing I do on more complex projects is take a copy of the objects when they are in a less developed condition and paste them off to one side (or into another instance of MoI) as backup to an earlier revision.
Thanks Ed - good suggestions. Andy
Hi Andy,
No it's simply an explanation for why it has not happened _yet_ in MoI.
> Alibre Design has no problem with it - see screenshot. <...>
Yes Alibre Design uses a geometry library called ACIS which has had something like 50 more man-years of effort put in to developing the shell and fillet geometry processing than the library that MoI uses.
I would recommend using Alibre to do your shelling instead of MoI, that way you won't have to worry about the ordering.
Shelling in MoI is pretty primtiive. When I started MoI I had hoped that the shell and fillet functions in the geometry library that I used would improve over time but the authors of the library have gone in a different direction than that.
I would like to license a different library to better handle those areas. That requires a lot of work as well though even just to investigate it.
I totally agree! Unfortunately it will require a lot of work to make this area behave like the user expects. I have not managed to scrounge up an extra 50 years of work time to make it happen as of yet.
Show messages: All
1-4
5-8
