Full Version: Does Curve 3 points show Tangent mode?
Show messages:  1-15  16-35  36-55  56-62
5 May 2021   [#36] In reply to [#35]
Hi Burr, can you please post a .3dm file with your curves set up that isn't working as expected?
5 May 2021   [#37] In reply to [#36]
Here's the file
J_Screw_martin.3dm
5 May 2021   [#38] In reply to [#37]
I must be doing something wrong here...
5 May 2021   [#39] In reply to [#37]
Hi Burr, it's because everything isn't on the same plane, if you go to the Top view and get them all placed on the same plane then you should be ok.
5 May 2021   [#40] In reply to [#39]
Ooooofff.
Thanks Michael..
5 May 2021   [#41]
If I have good understood the trick of Martin is brilliant of simplicity! Bravo!
LIttle variation
Same start with the Tangent circle...
I just made an Offset of the circle :)
(seems this time at any zoom there is no overpass of the arc! :)
5 May 2021   [#42] In reply to [#41]
Yes! There is no overpass of the arc! :)
5 May 2021   [#43]
Seems if i try to put a point on a "tangency"
point choices the vertical line and there is no real contact tangency?
Does this normal ?
it's a mega super ultra zoom :)
The green arc never touch the black vertical... and don't overpass it, (that is good :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/arc_tangency.3dm
5 May 2021   [#44] In reply to [#43]
Hi Frenchy,
I think that is just display, or even an accuracy setting, that is way beyond normal.... So MoI is giving the snap/pick as the same.
Try draw a line, then measure it... It is still beyond the decimal precision selectable in Moi.
Hand Drawn and snapped objects equal the same size.
So My Conclusion is just some abnormally unrealistic Zoom will produce odd things to look at..... :o
5 May 2021   [#45] In reply to [#44]
Agree - Most likely a math precision issue or artifact of the graphics engine.
Draw a square, copy it and assign a unique color to each. Use the alignment tool to left align one square against the other.
Zoom in to the sub-atomic level. There is a gap between the lines. Good enough for me :)
5 May 2021   [#46] In reply to [#45]
This is a nice read. You can skip down to the "position" bullet...
https://www.rhino3d.com/features/accuracy/
5 May 2021   [#47] In reply to [#44]
Yes at extreme zoom you'll start to see visible evidence of how floating point numbers work. Basically there are little teeny tiny jumps between representable numbers.
5 May 2021   [#48] In reply to [#47]
So MoI needs a sub-atomic, Nano button, so i can draw fingers on amoeba!!!
(Please read as a joke)
5 May 2021   [#49] In reply to [#32]
Hello folks :)
Any Simple Solution to this problem?
5 May 2021   [#50] In reply to [#49]
Hi Drillbit,
""""""Any Simple Solution to this problem?
Are you referring to this display thing we've been discussing?
If so, the answer is "dont zoom in to
.0000000000000000000000000314
And expect good results...."
We haven't really been discussing a "problem" but more of an artifact of a particular unusual use....
5 May 2021   [#51] In reply to [#50]
Hi :)
No, I am referring to a new problem! see the message I replied to! (message 10300.32 )
And yes! I understand ultra zoom may not be reliable. However I interpret the tiny gap between two tangent lines/curves as a sign of having tangent - in ultra zooms-
5 May 2021   [#52] In reply to [#51]
""""""No, I am referring to a new problem! see the message I replied to! (message 10300.32 )"""""
Hi Drillbit,
I understand. Sorry about the distraction....
5 May 2021   [#53] In reply to [#32]
Hi Psygorn,
> Hello guys, I have crossed upon new problem! You might be able to help :)
> I tried to create Tangent curve to red line at Point_1 and the green circle.
How about this - mirror green circle around magenta line, you can then use Circle or Arc tangent command, with the 2 green curves as the first tangent objects and third pick either snapping to Point_1 or getting a third tangent to the red line will work like this:
5 May 2021   [#54] In reply to [#53]
Oh wooow! Love that Genius method of yours :)
Again I would be happy to see it built in, is it possible? (No need to say I love your Genius method! :)
5 May 2021   [#55] In reply to [#52]
Hi, and tanx :)
But Michael already solved the problem! :)
