Full Version: Using a Surface as a Framework
Show messages:  1-15  16-35  36-51
23 Apr 2021   [#16]
OK, I have now tried this:
1. object obj in meshlab
2. Go to Filters -> Remeshing, Simplification and Reconstruction -> Simplification: Quadric Edge Collapse Decimation
3. Enter target of 1000 faces
4. Export
5. Use Michael's obj23dm converter, choose closed polygon for each face
6. Load into MoI
OK, looks good. A lot less clutter. But the "surface" is just a collection of triangles (closed curves) and there are no faces.
So what I want to do now (for example) is create a NURBS surface over the top, maybe just part of it, and then extrude that. But how?
Thanks, Andy
mesh-simplified.3dm
23 Apr 2021   [#17] In reply to [#14]
HI Andy,
> Is that doable?
Not really, at least not very easily. I guess it's technically possible but it's not an area of work that MoI is currently focused on so it's not going to be particularly easy.
If you don't want to change the data then to start with you would not want to use the sub-d importer because that applies a sub-d smoothing process onto the polygon control cage which does modify shapes making a kind of melty smoothed down result. This works fine when the polygon mesh has been set up from the beginning to be used for sub-d smoothing but otherwise not.
23 Apr 2021   [#18] In reply to [#16]
Hi Andy,
That's a process called "reverse engineering" and it's a pretty specialized and advanced type of use for CAD.
MoI is not designed to be a reverse engineering tool so it's not really a good fit to try doing this in MoI.
You might try Rhino, there are some reverse engineering tools made for it some info here:
https://wiki.mcneel.com/rhino/reverseengineering
23 Apr 2021   [#19]
Seems it's only triangles
try to make quadrangles before the importation! ;)
23 Apr 2021   [#20] In reply to [#18]
When you created your obj to 3DM converter what was the intended usage?
I tried creating a surface in Meshlab from the simplified point cloud (surface reconstruction), saved as a new obj, run through your converter, but still no faces. So I guess your converter does not generate faces?
Andy
23 Apr 2021   [#21]
I think if I could generate curves from silhouettes of the surface using the CPlane option, then I think that would get me most of the way there. Seems the silhouette feature won't work on my collection of triangles, because it's not an object?
Andy
23 Apr 2021   [#22] In reply to [#20]
Hi Andy,
Primarily for cases with structured objects, like boxes and cylinders, stuff like that which is easier to reverse engineering than freeform surfaces.
It's not an area that MoI is primarily focused on, which is why it's a separate tool and not a built in function.
Correct, the converter generates closed polyline curves, not faces. But you can turn triangles into faces using the Construct > Planar tool in MoI.
However, like I've been describing previously MoI and CAD programs in general are not designed to work on faceted triangle data.
23 Apr 2021   [#23]
If you want to create a nurbs surface with your map, I tested a method months ago.
Use Meshlab
- align your ground to be with a top view
- render with shader depthmap to create a heightmap
- scale the rendered image as you want for the precision (warning every pixel will give you a profile curve later)
- use the heightmap plugin in MOI. I think it's a Max plugin
- You will have a X or Y profiles (use only one if possible)
- Now you have curves to do a lofting (perhaps use loose option to smooth).
This lofting is a nurbs surface and you can use it
and delete curves.
A boolean operation can give you a clean surface which could be extrude or could be merged to have a real solid.
23 Apr 2021   [#24] In reply to [#21]
Hi Andy,
The silhouette command in MoI works on surfaces or solids, not on curves.
It's not designed to work with faceted data, it's main job is for building silhouette curves on curved surfaces.
23 Apr 2021   [#25] In reply to [#22]
"Primarily for cases with structured objects, like boxes and cylinders, stuff like that which is easier to reverse engineering than freeform surfaces."
What are the steps to reverse engineer a structured object?
Andy
23 Apr 2021   [#26] In reply to [#23]
Thanks Phiro - sounds interesting, I will give it a try. Andy
23 Apr 2021   [#27] In reply to [#26]
Here the height by Max Smirnov ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7547.52
place file(s) inside the moi commands folder
relaunch Moi
Press Tab and write _heightmap
23 Apr 2021   [#28] In reply to [#26]
A problem you could have with your beginning object is the overhangs in the ground and the holes.
The overhangs gives only the higher point and hide lower points in depthmap. Holes give a 0 level, not an hole.
But the result could be like this 2 surfaces.
Yes Michael, you're right...
it's not an orthodox CAD software usage...
23 Apr 2021   [#29] In reply to [#25]
Hi Andy,
Draw lines for planar spots, use Circle or Arc through 3 points snapping on to triangle corners, use the lines and arcs to extrude surfaces.
23 Apr 2021   [#30]
You can have easily some curves of your object
here the horizontal arounding after an extrude :)
make the same on some vertical sections planes on this same object
At the end make network...
23 Apr 2021   [#31] In reply to [#25]
Hi Andy,
There's an example here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9208.1
23 Apr 2021   [#32]
How about this?
1. Create object of precise shape and size
2. Slice object using surface to create the back of the object
3. Offset surface X mm
4. Slice object again with surface to create the front of the object
I.e. splitting the object into three parts and keeping only the middle.
Is that possible?
Andy
23 Apr 2021   [#33] In reply to [#32]
Of course yes but it's completly different that you want to make with your "triangulated" object! ;)
If you create directly with "Nurbs" curves, Surfaces etc ... you will not have problem!
23 Apr 2021   [#34] In reply to [#32]
Hi Andy,
> Is that possible?
No probably not easily if the "surface" is a bunch of triangles instead of an actual smooth surface. It will be difficult to offset something like that.
23 Apr 2021   [#35] In reply to [#7]
Hi Andy,
So your surface looks like Crumpled paper!!!
I opened it in 3dcoat without modifying it. Then I ran a command called "Instant Mesh" with the auto setting. I set 3200 as the poly count. If you really wanted or needed quality results, you would retopo it properly i guess.
The result below.
The retopoed mesh along side the same file imported using MoI's SubD tool:
And the Imported Mesh, alongside running Max's SubDiv9 on it.
In both cases, the imported mesh is there by means of Max's ImportObj Command.
I wouldn't try to work with the original 3dm file....
