Full Version: Connect two circles with a tangent
Show messages: All  1  2-8
10 Apr 2021   [#2] In reply to [#1]
Hi Andre,
> If I have two circles, is there a way to construct a line that is tangent to both circles?
Yes, make sure you have Object Snap enabled in the bottom toolbar, and that you have not inadvertently turned off the "Tan/tan" snap type.
You'll then be able to get a line like that using the Line command like this:
10 Apr 2021   [#3]
Oh wow, I didn't notice the starting point snaps as well. That's awesome.
10 Apr 2021   [#4] In reply to [#3]
PS Your circles must be on the same plane !!! ;)
10 Apr 2021   [#5] In reply to [#3]
Hi Andre, yes there are 2 snaps - tan/tan and perp/perp - that modify both the start point as well as the end point when it engages.
27 Apr 2021   [#6]
Worked for me for the first two lines but then wouldn't work for the next one. V4. Circles are on the same plane. Andy
27 Apr 2021   [#7] In reply to [#6]
Hi Andy, looks like there's some kind of bug in handling the tan/tan snap when it's also on a surface.
Does it work ok for you if you temporarily hide the solid?
27 Apr 2021   [#8]
Hi all.
If the body is hidden, it works normally.
tanTan.3dm
