Full Version: Real size grid
Show messages:  1-13  14-22
12 Feb 2021   [#14] In reply to [#13]
It is perfect for my needs - thank you for that golden tip, Burrman !
As I am currently designing small scale objects with an emphasis on their aesthetical
values, it helps me to evaluate them under their exact size on screen - and such a virtual
Caliper is definitely easier to handle than to hold one against the monitor.
12 Feb 2021   [#15] In reply to [#12]
Hi Tom,
> "as far as I know there isn't any way for a program"
> Have a look at it, Michael" !
I did and it doesn't do that either. It measures pixels and shows inches just by a fixed conversion factor of 96 dpi. On my system here when it says 5 inches it's actually around 4 1/2 inches.
So it doesn't know your physical screen size automatically, but looks like it has a calibration method so you can get it set up for your environment.
12 Feb 2021   [#16] In reply to [#15]
You are eight, it is possible to calibrate it.
12 Feb 2021   [#17] In reply to [#16]
Hi Tom, also you can calibrate MoI in a similar way like Colin describes above.
Something like - draw a 10 inch line, then zoom until your line matches 10 inches on a ruler and now you're calibrated and any dimensions that you draw will be at real size until you alter the zoom or viewport size.
12 Feb 2021   [#18]
This is similar in concept, but adds some bells and whistles.
It's Free
IC Measure provides powerful tools for the manual measurement of circles, lines, polygons and angles. The convenient user interface enables the easy measurement of lengths, angles and surfaces directly from the image displayed on the monitor. Measurement data can be exported as CSV file.
IC Measure - manual on-screen image measurement and image acquisition
Dimension Images
Load photos from disk.
There is a toolbar tab that says "Microscope", think of it as my "Photo-Rig-Setup's" saved calibration.
13 Feb 2021   [#19] In reply to [#17]
Michael, the zoom factor cant be entered manually or even stored, am I right ?
13 Feb 2021   [#20] In reply to [#18]
Thats an amazing find - thank you !
13 Feb 2021   [#21] In reply to [#19]
Hi Tom, the zoom factor is part of the view definition, it will be saved when you save to a .3dm file and reload.
The zoom factor value for an ortho view does not have a spot in the regular UI for directly editing it but it can be accessed by script.
script: /* display top view zoom factor */ moi.ui.alert( moi.ui.mainWindow.viewpanel.getViewport( 'Top' ).fieldOfViewAngle );
script: /* set top view zoom factor */ moi.ui.mainWindow.viewpanel.getViewport( 'Top' ).fieldOfViewAngle = 30.0;
13 Feb 2021   [#22] In reply to [#21]
Thats awesome.
So by entering the desired zoomfactor into the command line of the script I
can always return the "real world" size.
MOI feels like a silken glove - the smoothest workflow ever ;-)
