Full Version: V4 beta Dec-21-2020 available now (v4 release candidate)
Show messages:  1-12  13-32  33-43
23 Dec 2020   [#13] In reply to [#12]
Hi Michel,
> The previous beta had a problem with fbx export and accented characters.
> This is now OK in v4 beta 2020-12-21.
Great! Yes actually the fix listed above for SKP export with accented characters also applied to FBX export as well. I've updated the release notes.
Happy Holidays!
24 Dec 2020   [#14]
Well I guess I'll start the rollout of the v4 final release tomorrow!
I think the first step will be setting up free v4 upgrades for any v3 purchases made since Aug 1, 2018. If that seems to go well then I'll set up the order pages the next day after.
Then setting up trial versions and some web site updating to do.
24 Dec 2020   [#15] In reply to [#14]
Note that this Dec-21 beta release has the same code as the v4 final release and the beta does not expire until Oct 8, 2021 . So you don't need to be in a rush to update really.
24 Dec 2020   [#16]
Congratulations Michael on getting to this major milestone! I look forward to being able to purchase the upgrade as it is a small offering of thanks that I can make for the years of effort that you have put into this release. Wishing you a very Merry Christmas!!
--Larry
24 Dec 2020   [#17] In reply to [#16]
Thanks Larry! And a Merry Christmas to you as well!
24 Dec 2020   [#18] In reply to [#14]
Free V4 upgrades for V3 licenses purchased after Aug 1, 2018 are now available at https://moi3d.com/4.0/upgrade.php .
24 Dec 2020   [#19] In reply to [#18]
Wow Michael! You let me choose my personal Christmas gift 2020 :-)
Thank you for your incredible work and for your kindness in supporting this community.
Merry Christmas to you and your family and Merry Christmas to all members of this wonderful forum.
Giovanni Benedetti
24 Dec 2020   [#20] In reply to [#19]
Thank you Giovanni , and Merry Christmas! :)
25 Dec 2020   [#21] In reply to [#1]
36.7 MB..... Amazing!
Thanks for all the hard work Michael... And thanks to JG and the Rabbit too!
Merry Christmas.
Burr
25 Dec 2020   [#22] In reply to [#21]
Thanks Burr, Merry Christmas!
26 Dec 2020   [#23]
I think I'm missing something.
I purchased MoI on Oct 26, 2018 and it let's me download V4, but when I try to launch MoI it requires V4 license key and don't accept V3 one.
26 Dec 2020   [#24] In reply to [#23]
Hi Mr. Yuri, yes you need a V4 license key to run the final v4 release, not a V3 key.
The upgrade page will give you a new V4 license key it should be shown immediately above the download links:
Is it not showing up there for you?
You can go back to https://moi3d.com/4.0/upgrade.php and put in your V3 license key again and it will show you your new V4 license key and download links there again.
Copy the license key which is the text beginning with VER4 and save it off in a text file somewhere so you can reference it later if needed.
Also you can go to https://moi3d.com/reinstall.htm and request your license keys to be sent to you through e-mail, that should send you both your V3 license as well as the new V4 license key which was generated for you.
26 Dec 2020   [#25]
I did not compare those keys so I thought it's just showing my current one.
Thanks for quick help.
I'm up and running.
Have a wonderful christmas and happy new year :)
26 Dec 2020   [#26] In reply to [#25]
Thanks Mr. Yuri, Merry Christmas and Happy New Year!
26 Dec 2020   [#27]
Ok, so far so good, continuing the v4 rollout.
Order pages for v4 full version and upgrade versions are now active at http://moi3d.com/purchase.htm .
If you've ordered v3 after Aug 1, 2018 you can get a free v4 upgrade at http://moi3d.com/4.0/upgrade.php .
26 Dec 2020   [#28] In reply to [#27]
Thank you Michael.
One upgrade purchased and installed.
Lately Windows 10 has been warning about downloading some other programs, which occurred with the upgrade.
Selecting "keep" permits the download, which is of course harmless with MoI4.
Then when some other programs are installed, including the upgrade, Windows 10 defender again warns, but still permits installation.
ps, SanDisk has a new 1TB SSD, about the size of a thick credit card. (Costco).
26 Dec 2020   [#29] In reply to [#28]
Thanks Brian!
26 Dec 2020   [#30] In reply to [#28]
Thanks Michael for all the hard work - excited to get started with version 4.
26 Dec 2020   [#31] In reply to [#29]
Part of max's custom ui fails in the v4 release. It is the lighting presets link. Worked in the last beta just fine
Trying to figure out what's different.
You did say there is virtually no difference in the dec beta and this release?
I get plugin not found "else code"
26 Dec 2020   [#32] In reply to [#31]
Hi Burr, Max's lighting presets depends on an entry in the moi.ini file being populated with the information from Dino's plug-in here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.43
If it worked in the last beta then probably the thing to check is if you had the last beta set up with its own moi.ini file separate from the one that the v4 release is currently using.
Either run that plug-in in the v4 release so that section of the moi.ini file gets populated, or copy the moi.ini file being used with the last beta to the one being used by the v4 release. Or you could copy over just the one entry that it's looking for which is LightingOptions=<...>
Does that get it working?
