Full Version: BoundingBoxCenter for-loop?
15 Dec 2020   [#1]
Is there an argument (or existing script) that makes BoundingBoxCenter operate per-object in a multiselection?
For example, if I have a number of paths selected and I want to add points at each objects center, rather than the group center.
Also, is it possible to concatenate actions in a hotkey command?
e.g. Copy > Paste > Move BoundingBoxCenter ?
I've tried emulating what I see in some other for-loop scripts and key-binds but I'm not having much luck.
Much obliged for any help!
Nate
15 Dec 2020   [#2] In reply to [#1]
Hi Nate,
Try the attached script.
Not really, right now you would make a script to do something like that, and inside the script you would combine the script code that's inside the Copy, Paste, and Move commands instead of calling those commands in sequence.
In the future I would like to set up a method for stringing things together at the command level too though.
For the particular case of Copy to clipboard, Paste and Move you would probably just use the Transform > Copy command instead.
Thanks, - Michael
BoundingBoxCenterIndividual.zip
15 Dec 2020   [#3] In reply to [#2]
Ahhh, I see!
Thanks man, this works perfectly.
Also for Transform > Copy.. I totally overlooked that.
Does exactly what I was after + keybinds perfectly to 'Copy BoundingBoxCenter'
Thank youuuuuuuu^^
