Node Wish List
9581.298
Thank you MO!
Here is another one you might like.
Modification to the Node Editor to allow the program name to always appear at the bottom of the display.
Program file 'main.js'
Modify this location:
	//rendering
	if (this.onRender) this.onRender(canvas, ctx);
	//info widget
	if (this.show_info) this.renderInfo(ctx);
Add the five lines to the info widget area:
	//rendering
	//info widget
	///////////// 4-17-2022 wjh
	ctx.clearRect(0, canvas.height - 20, canvas.width, canvas.height);
	var dpir = this.pixelRatio * this.uiRatio;
	ctx.font = "bold " + 14 * dpir + "px Arial";
	ctx.fillStyle = LiteGraph.NODE_INFO;
	ctx.fillText(this.graph.filename, 5, this.bgcanvas.height - 3 * dpir);
Comment out this line. It is a part of a different routine not required.
//  >>> ctx.fillText(this.graph.filename, 5, this.bgcanvas.height - 3 * dpir); // 4-17-2022 wjh
From this location:
LGraphCanvas.prototype.renderInfo = function (ctx, x, y) {
	x = x || 0;
	y = y || 0;
	ctx.save();
	ctx.translate(x, y);
	ctx.font = 12 * dpir + "px Arial";
	if (this.graph) {
		ctx.fillText("Total: " + this.graph.elapsed_time.toFixed(0) + " ms", 5, dpir * 15 * 1);
		ctx.fillText("FPS:" + this.fps.toFixed(0), 5, dpir * 15 * 2);
		ctx.fillText("F: " + this.frame, 5, dpir * 15 * 3);
		ctx.fillText(this.graph.blocked ? "Graph blocked" : "", 5, dpir * 15 * 4);
	} else ctx.fillText("No graph selected", 5, 13 * 1);
	ctx.restore();
Size: 75.5 KB, Downloaded: 72 times, Dimensions: 603x529px
