Multiple symmetry update
7888.9 In reply to 7888.6
Hi Tom,
> Here is the textfile - whre should I insert what.
It looks like you're trying to edit the .htm file there - that contains the definition of all the UI controls like the prompts and push buttons and things like that.
You're probably more interested in editing the .js file which contains the script logic for the command.
Anyway, I've attached above a new command script which I think does what you need, copy it into your commands folder and try running it.
