" I've attached a version using regular scripting that does it, by using the Rotate command with "Make copies" set to true 6 times and setting history updates to be turned on for the generated objects. "
Wow what support thank you so much for taking the time ! Well it does work with V2 too as I see.
""It looks like you're trying to edit the .htm file there - that contains the definition of all the UI controls like the prompts and push buttons and things like that:""
I took a look at the html file as I managed to achieve changes by editing the html before in the circular array html :
| <moi:Text textid="ArrayCircular item count label"> |
<input id="NumItems" default="3" class="unsignedintegerinput inputwidth"> |
Thanks again to you guys the support in this forum is the best I can think of -T-
