Hello James,
Thank you!
1) Does new node Points2/PTS2pts perform any functions beyond Objects/ObjtoArray?
Yes, but I like the name and it wasn't clear for me at the time I wrote it:-)
2) Are Transform2/FlowObj & Transform2/mFlowObj now fully redundant since Max's version Transform/Flow?
Yes
3) Is Objects2/intersectObj now redundant since new Objects2/intersectObjMP?
Yes
4) Does Points2/Path_Array do anything not already done by Points2/mPath_Array?
No!
5) Was Construct2/mLoft made redundant by the addition of Construct2/mLoft2?
Yes
6) Is Construct2/Project now redundant since new Construct2/ProjectMP?
Yes
7) Wasn't Objects2/Concat2 made redundant by Max's updated Basic/Concat?
At the end - yes.
Okay - we can now delete the redundant nodes, but which name for the left one?
Or place them in an compatibility file?
By the way - I think about a small documentation - a small html files for every node, you can call by the RMB. My problem: I don't have any html skills. Netbeans alerts to me " use CSS" okay???. Could you or someone else make some tests and give me some tips or create a template?
For testing you have to replace basicfunctions.js in the libs folder - construct2.js and create a folder under extensions\Documentation\EN\ and place the sweep.html into it. Language setting in Moi should be English. When you insert the sweep node in NE, you should find then a info under the RMB.
Thanks in advance
and have a nice day
Karsten
