Hello,
I want to share my last nodeeditor investigations:-) It's only a draft for playing with it. It's based on Max Smirnov's Alpha Version 0.23. I've try to split new nodes from Max core development (I hope I have nothing forgotten). I have placed the polyline node from James - thanks for it - in factories2. Attention if you want to use your old nodefiles. If You load them with this version they will be dirty. I added a Selection node that store the name of a single Object - so you can reload File and nodefile. It's not perfect, but it works in a first step.
Most of the stuff will be obsolete when Max's new version is comming up.
The demofiles shows a simple mechanism with clash detection.
Kind regards
Karsten
