What's a good way to cut grooves in surfaces?
5861.1
Like a battery compartment door that's basically a tiny groove in a rectangle shape on the main surface.
I tried an example I saw on this forum where you project lines on a sphere and then sweep the lines and boolean the two to create grooves. However when I try that on other surfaces I have created, the problem is that after cutting into the object you can see that there is no thickness on the surface so in this case the groove is just a rectangular hole in the surface.
I'm just wondering what methods are used to accomplish these grooves when using a hollow object or surface.
David
