| I created a drawing of a rail with a slider on it.  I created the slider as a solid and then put four holes in it using boolean diff.  Everything looked fine so I saved the drawing.  I now realize that the holes are wrong.  If they needed to be bigger, I would just use another diff operation, but they need to be smaller.  I wish I could just "undo" the operations and make the holes disappear, but since I've done a save, I can't.  Is there a way remove or "fill in" the holes so I can start over without having to recreate the slider from scratch?  I've included the drawing so you can see what I'm talking about.Thanks,
 Mark
