A bit because the objects are slightly rotated.. Like .0007... Which will make little sliver calculations fail..
Here i extracted just the bottom edges of the model:
If you then go to the front view and zomm in on them, they will look like this:
I'll look and see if i can rotate them true so the boolean will work ok.
