Hull Lofting Experiments and Issues
3002.11 In reply to 3002.1
Hi Mark I think I get it - if I understand correctly, you are doing a loose loft using these profiles:
But then the part that you want to nail down more is actually this side of it here:
Is that correct?
But basically Loft does not give you such specific control over the side edges like that, sweep or Network are the ones that give side edge control. But more pressure to constrain a shape tends to make for more compressed undulations in it as well which I'm sure you've run into a lot.
But do these pieces here have to be separate surfaces:
What about making a larger single Loft that includes those pieces all within it, that would help to make them touch properly. You can have a sharp corner in a loft profile, that's ok.
That would also involve making some of the rear sections be extended up somewhat extra, and then if need there to be a space in that area you would cut it out with a trim here:
