Close curves?
2752.8 In reply to 2752.7
> Curiously when I restart the prog, that's working!!!
You must have typed the other name in once before you had copied the file over.
When you launch a command, MoI caches the result into memory so that it does not have to access the disk anymore to run that command after that. That includes remembering if there was no command matching that name.
