Small request here....Can we have an option to auto connect a straight line from the end points of an offset line with the end points of the original line please? If this could be paired with an auto group function option it would be a bit of a time saver for me at least. Just thinking about drawing walls or any shape that needs to be extruded with a thickness, with this you would draw your inside line, use the offset comand to specify the distance and then you have a shape that is ready for extrusion. Currently we have to manually connect the ends and join. Hoping this doesn't sound like a big job or classed as UI clutter.
