| Thanks for the comments.
Frenchy:
>>Mad dentist :)
Yes, the chair was based on dentist chair pictures I found on the web ;-)
>> Remember this sort of thing
Yes I do - you should see under my desk :-)
kevjon:
Yes, I plan to texture as well.
Michael:
I turned the the hidden lines off for the major assembly stuff. I usually had 3 or 4 instances of MoI running at a time with various view settings depending on the complexity of the part I was modeling. Easy to cut and paste from one to the other. I set up the scene as I went along and made good use of the cplane when adding bits. In the end I had to keep the panels for the main control station (the one with the monitors) separate from the main assy file.
Should be easier to manage when you have the grouping stuff done.
Here's a grab of some of those nice ngons MoI hands over to modo :-)
