| Theme problem SOLVED!
 I was copying the shortcut command from a PDF program which opened the NEPlus document PDF file.
 Apparently the PDF program put in some BAD characters of some sort.
 So copying the shortcut code from MO's code on the MoI discussion worked fine.
 I think that the PDF reader program was from MS Edge(???)
