| Hi Brian,
 > The shortcut resizable window setting of the new version does NOT seem to work.
 Is there any error message displayed?
 If you get an error dialog that says "ReferenceError: Can't find variable: theme" then it probably means you only got the last line (starting with "moi.ui.createDialog") copied, make sure you copy all 3 lines.
