Removing duplicate lines
11111.2 In reply to 11111.1
Hi Matadem, there is a RemoveDuplicates command that might help with that:
https://moi3d.com/4.0/docs/moi_command_reference10.htm#removeduplicates
Select all the lines, then press the Tab key and type RemoveDuplicates and then press Enter to run that command.
There isn't anything set up for duplicates to show in a different color. However, when there are duplicates the display will be a little darker in those spots. It's pretty subtle though.
