groups in v5beta
10815.7 In reply to 10815.4
Michael,
> It's the same basic structure as in Illustrator
You're right. I thought that groups in Illustrator and groups in Corel behaved very differently, but that's not true. So, I dug into why I have so much trouble with Corel, but not with Illustrator. I think the answer is that in Corel I can't drill down into a group (select a subset of the group), but in Illustrator I can do this in the Layers Palette. Your version is better than both because I can drill down both in the Scene Browser and in the Viewports without needing to use a special selection tool.
Is there a way to select a range of items in the objects section of the browser, for example by selecting the first and then shift-click on the last?
Something that causes me some confusion is that the name in the Object Properties Panel in the upper right corner doesn't immediately get updated if I change the name of an object by clicking on the name of another object in the Objects section of the browser. For example, I select part of "Unnamed"
and then click the text "hatch" in the Objects section. The yellow selection indicator moves next to hatch, but "unnamed" is still shown in the Object Properties Panel:
Another issue I've run into is that selecting a group of points doesn't cause a yellow halo to appear around those points in the viewports. I see an Edit Frame in the ortho views, but nothing in 3D:
- Peer
