Modified version of Max's Scripts menu
10353.22 In reply to 10353.20
Hi Suiyan,
Re:
> Added the number of blank lines for easy positioning. But it still
> reduces the number of lines between plugin names.
Blank lines in code have no effect on how javascript or html works. They will not become blank lines in the graphic display that the code generates.
Adding blank lines to the displayed list would require many changes to the .htm file to make it work in a different way that allows blanks. Right now there are multiple steps that either discard blanks or will put them in a different position from where you want them.
- Peer
