Modified version of Max's Scripts menu
10353.13 In reply to 10353.12
Hi SUIYAN,
Glad that Michael's fix resolves the issue you noted.
As mentioned, I wanted to avoid having the hard-coded list of internal commands but that turned out to be more of a challenge than I had time for. Are you able to rename the other script files in the commands directory and have the international characters display properly in the menu? I never thought about that particular use-case.
--Larry
