V5 Wish List
10114.636 In reply to 10114.635
Hi co3Dprints,
> 1. by default not having the ratios linked on new objects (maintain proportions) when you want
> to change the X axis length for instance.
If you put the attached file SetEditSizeMenuUniform.js into the appdata startup folder, you should then have "Maintain proportions" unchecked initially.
> 2. Sure there is a hotkey but switching units e.g. inches to millimeters would be great
> as a button in gui.
It's in the UI under Options > General > "Unit system" .
> For instance when putting a caliper to something. I wish diameter was the default
You can make diameter the default by editing moi.ini (Options > General > "Edit .ini file" button) and set:
[Commands]
UseDiameterDefault=y
> <....> or have a simple toggle in that field that activates diameter input instead of radius.
There is a toggle for switching a radius field between radius or diameter input by clicking the label with the "cycler" arrow to the left of the field:
Hope that helps!
