Hi Larry,
> One limitation is if the list of objects fed to the intersect is too broad there may be other
> intersections that generate points which are unrelated & this would lead toward more
> complexity to eliminate those points.
Ok, but how do you want me to implement the "nearest neighbor GeomObject method" without running into these very same issues?
At some point I would like to have an option when you're booleaning a solid with a planar curve to look at the results and only keep the cut that was closest to the curve, sort of like an automatic subset. Maybe that would help but I'm not sure when I'll be making that.
