Hi Scott,
> Would adding a redundant 'd' field in the polygon settings section (under SIDES?) possibly
> make this workflow simpler without causing the conflicts you mentioned earlier? Or would
> a redundant 'd' field be potentially confusing/inconsistent with the MoI UI?
Well the problem is I'm not sure about the answers to these questions so that makes me
hesitate.
One thing that I have done though is I've made Ctrl+Tab work to always put keyboard focus into
the XYZ input control and not into the command specific options area like plain Tab does.
So you'll be able to use Ctrl+Tab and then type a number into the XYZ input to set distance
constraint without any clicks needed.
