V5 Wish List
10114.370 In reply to 10114.369
Hi James,
> Is it just wishful thinking, or does the brevity of your more recent answer hint at the possibility that
> this is something that you given some thought to enacting?
It hasn't really been on my radar. I took a quick look and I got a little discouraged that the selection
prompt for Extrude says "Select curves, edges, or faces to extrude" and then adding in points means
I have to either make that prompt kind of excessively verbose, or I guess shorten it down to say "Select
objects to extrude" I guess.
> Rereading that earlier post, ( http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=6925.454 )
> I was reminded that back then we also discussed making control points addressable. Although I can't
> find the specific post, I recall (correct me if I'm wrong) that you would be investigating point indexing
> for a future release. Is this part of the road map for V5?
There is a first level of this implemented in the first v5 beta currently, check near the end of the release notes:
"Edit points scripting - Add scripting interface on objects for:"
http://moi3d.com/forum/index.php?webtag=MOI&msg=10652.1
