Hi Tudor,
> i'll expain behind the scene: ex chamfer - and move a point, actions will be enter edit mode, select points,
> move, exit edit mode(show points) -> 4 actions per 1 operation
If you want to move just one point you don't need to select it and then move it in separate steps you can just click and drag on the point.
You can also turn off points by hitting the Esc key instead of clicking on Edit > Show pts.
I experimented with making a script that would turn on points for a single selected object, let you drag a point and then turn off points automatically. I wasn't able to make it for v4 because edit points aren't accessible by scripts but I have added that in for v5 so a script for doing this will be possible in v5.
