Dear Michael,
> I'd probably try Array circular with the center point for the array at the center of the object with a vertical step applied. That will make a vertical stack of rotated objects and you can then arrange that onto a circle using Transform > Deform > Flow.
There is an attached file to this reply, I was not able to scatter the curves around a circle. would u please take a look at it and then tell me what I am doing wrong?
I used the flow command and I tired to make sure that the length of vertical line is equal to the perimeter of the circle. However, I was not able to achieve what I wanted ( I want to scatter those squares around the circle and have them equally spaced.)
