Hi Tony, I expect it will be quite a while before a lot of direct Sub-d modeling tools are available in MoI. When they start out they will be focused on pretty light duty simple shaping. I don't expect that they will be a replacement for a dedicated poly modeler anytime soon.
The SubD converter that is in MoI version 4 should enable you to have a good workflow using a separate dedicated poly modeling program to construct the SubD control cage and then importing that into MoI.
So if you want to do some sub-d modeling I recommend to go with a dedicated modeling program for that now.
