| > A modifier to override snap could be a useful productivity feature.> For example pressing "Alt" or "Ctrl" while clicking could temporally turn of snapping.
 Hi Marc, how about Alt.  But do you think it should temporarily disable all kinds of snapping, like grid snap and straight snap in addition to object snap?  Or just object snap? I kind of think maybe everything would be a good idea.
 > In the same train, a way to "isolate" a snapping mode in the object snap flyout
 > would be handy. This could permit to select tangent mode, for instance, without
 > unclicking all of the others one by one.
 I think this would be feasible, I suppose I could hook it up to both right-click as well as a modifier key.
 But are you running across situations where you need to turn on or off these individual modes?
 If so, could you show an example of one? I've generally tried to make it work well to keep all the different modes active all the time. If you're running into problems with that, if I could see the situation it might help me figure out how to improve things.
